Kzoo Posted June 9, 2022 Share #1 Posted June 9, 2022 I have a 1999 25Hp 2 stroke outboard engine that has been in storage for about a dozen years. It worked great before it was put in storage. I'm about ready to fire that thing up but I wanted to ask (as opposed to Google) if there a recommendation for something to put in the cylinders before hitting the start button? Next on the list would be to replace the lower unit gear oil. Link to comment Share on other sites More sharing options...
jsharr ★ Posted June 9, 2022 Share #2 Posted June 9, 2022 Some light machine oil would work, or some 2 stroke oil diluted with a bit of gas. I would consider replacing the impeller after sitting that long. Be ready to replace fuel pump and rebuild the carb, unless it was put away right. 2 Link to comment Share on other sites More sharing options...
jsharr ★ Posted June 9, 2022 Share #3 Posted June 9, 2022 Down here, I would check the carb throat for mud dobbers too. Those bastards will fill an engine cowling with their mud huts. 1 Link to comment Share on other sites More sharing options...
Further Posted June 9, 2022 Share #4 Posted June 9, 2022 A couple squirts of oil in the cylinders and crank it with the plugs out to spread the lube around. Fogging oil is made for this, a squirt in the carb would be a good idea Link to comment Share on other sites More sharing options...
jsharr ★ Posted June 9, 2022 Share #5 Posted June 9, 2022 Are you starting it in a test tank or using ear muffs to supply water? If using muffs, they will mask a bad impeller, as you are sending pressuried water into the water intake. If you are running in a tank or on a boat in the water, make sure that engine is putting out water from the indicator line. Make sure it is not overheating. 2 Link to comment Share on other sites More sharing options...
Further Posted June 9, 2022 Share #6 Posted June 9, 2022 And no ethanol gas when you fire it up 1 Link to comment Share on other sites More sharing options...
Parr8hed Posted June 9, 2022 Share #7 Posted June 9, 2022 There is a channel on the you tubes called "that boat guy". He does outboards a ton. It would be good to watch a few of his vids. Pretty informative. Link to comment Share on other sites More sharing options...
BR46 Posted June 9, 2022 Share #8 Posted June 9, 2022 13 minutes ago, Further said: A couple squirts of oil in the cylinders and crank it with the plugs out to spread the lube around. Fogging oil is made for this, a squirt in the carb would be a good idea This ^^^ 2 Link to comment Share on other sites More sharing options...
jsharr ★ Posted June 9, 2022 Share #9 Posted June 9, 2022 29 minutes ago, BR46 said: This ^^^ This too v v v 2 1 1 Link to comment Share on other sites More sharing options...
Kzoo Posted June 9, 2022 Author Share #10 Posted June 9, 2022 1 hour ago, jsharr said: Are you starting it in a test tank or using ear muffs to supply water? If using muffs, they will mask a bad impeller, as you are sending pressuried water into the water intake. If you are running in a tank or on a boat in the water, make sure that engine is putting out water from the indicator line. Make sure it is not overheating. I have muffs. Thanks for the heads up on the impeller. Link to comment Share on other sites More sharing options...
Kzoo Posted June 9, 2022 Author Share #11 Posted June 9, 2022 1 hour ago, Parr8hed said: There is a channel on the you tubes called "that boat guy". He does outboards a ton. It would be good to watch a few of his vids. Pretty informative. I was going to look up UTube vids. Thanks for the direction. 1 Link to comment Share on other sites More sharing options...
Kzoo Posted June 9, 2022 Author Share #12 Posted June 9, 2022 1 hour ago, jsharr said: Down here, I would check the carb throat for mud dobbers too. Those bastards will fill an engine cowling with their mud huts. I found a dead family of stink bugs... Link to comment Share on other sites More sharing options...
12string Posted June 9, 2022 Share #13 Posted June 9, 2022 2 hours ago, Kzoo said: I have muffs. Thanks for the heads up on the impeller. Consider replacing or at least pulling the impeller prior to starting. That could turn to shrapnel pretty quickly. If you pull it, duct tape to seal the cuff to make sure the hose pressure feeds the engine. Just don't run the hose full blast. Is it an Evinrude or a Kia? 1 1 Link to comment Share on other sites More sharing options...
Popular Post maddmaxx ★ Posted June 9, 2022 Popular Post Share #14 Posted June 9, 2022 Kia might buy it from you to put into some guys car. 1 1 3 Link to comment Share on other sites More sharing options...
MickinMD ★ Posted June 9, 2022 Share #15 Posted June 9, 2022 5 hours ago, Further said: A couple squirts of oil in the cylinders and crank it with the plugs out to spread the lube around. Fogging oil is made for this, a squirt in the carb would be a good idea THIS! Link to comment Share on other sites More sharing options...
Popular Post Thaddeus Kosciuszko Posted June 9, 2022 Popular Post Share #16 Posted June 9, 2022 Since somebody already said duct tape, I'm going to have to say WD-40. 4 1 Link to comment Share on other sites More sharing options...
Kzoo Posted June 10, 2022 Author Share #17 Posted June 10, 2022 2 hours ago, Thaddeus Kosciuszko said: Since somebody already said duct tape, I'm going to have to say WD-40. This is the kind of advice I was looking for. 1 1 Link to comment Share on other sites More sharing options...
Ralphie ★ Posted June 10, 2022 Share #18 Posted June 10, 2022 43 minutes ago, Kzoo said: This is the kind of advice I was looking for. Well you are Shirley in the right place. Link to comment Share on other sites More sharing options...
Popular Post BR46 Posted June 10, 2022 Popular Post Share #19 Posted June 10, 2022 9 hours ago, Kzoo said: I have a 1999 25Hp 2 stroke outboard engine I could fix it for you......I mean double the HP for you. 2 2 2 Link to comment Share on other sites More sharing options...
Parr8hed Posted June 10, 2022 Share #20 Posted June 10, 2022 8 hours ago, BR46 said: I could fix it for you......I mean double the HP for you. Can you turbo a 2 stroke outboard? Link to comment Share on other sites More sharing options...
BR46 Posted June 10, 2022 Share #21 Posted June 10, 2022 1 minute ago, Parr8hed said: Can you turbo a 2 stroke outboard? You can turbo anything 1 Link to comment Share on other sites More sharing options...
Parr8hed Posted June 10, 2022 Share #22 Posted June 10, 2022 8 hours ago, BR46 said: I could fix it for you......I mean double the HP for you. 2 minutes ago, Parr8hed said: Can you turbo a 2 stroke outboard? 1 Link to comment Share on other sites More sharing options...
Parr8hed Posted June 10, 2022 Share #23 Posted June 10, 2022 4 minutes ago, BR46 said: You can turbo anything HOLY SHIT 1 Link to comment Share on other sites More sharing options...
Thaddeus Kosciuszko Posted June 10, 2022 Share #24 Posted June 10, 2022 4 hours ago, BR46 said: You can turbo anything Yup, including Floyd R.: 1 Link to comment Share on other sites More sharing options...
Popular Post Kzoo Posted June 27, 2022 Author Popular Post Share #25 Posted June 27, 2022 Got back at it this afternoon. It took a bit of cranking but I got it started. Impeller looks to be working just fine. The engine is running just fine. 5 Link to comment Share on other sites More sharing options...
Thaddeus Kosciuszko Posted June 27, 2022 Share #26 Posted June 27, 2022 8 minutes ago, Kzoo said: The engine is running just fine. I would suggest taking it out for a three hour cruise, just to be sure. 1 1 Link to comment Share on other sites More sharing options...
Dottleshead ★ Posted June 27, 2022 Share #27 Posted June 27, 2022 7 minutes ago, Thaddeus Kosciuszko said: I would suggest taking it out for a three hour cruise, just to be sure. Like head for the center of the lake?? Link to comment Share on other sites More sharing options...
maddmaxx ★ Posted June 27, 2022 Share #28 Posted June 27, 2022 53 minutes ago, Kzoo said: Got back at it this afternoon. It took a bit of cranking but I got it started. Impeller looks to be working just fine. The engine is running just fine. I still don't understand how you are going to use this on two cycles. Do you mean to move it from one to the other or just cobble up some sort of frankenbikes. Link to comment Share on other sites More sharing options...
