Chris... Posted December 15, 2023 Share #1 Posted December 15, 2023 1 Link to comment Share on other sites More sharing options...
BuffJim Posted December 15, 2023 Share #2 Posted December 15, 2023 I’ve had my house 10 years and never once did I think I needed to power wash the driveway. Link to comment Share on other sites More sharing options...
jsharr ★ Posted December 15, 2023 Share #3 Posted December 15, 2023 Could you use photoshop and make it look clean in the pic? 1 Link to comment Share on other sites More sharing options...
Razors Edge ★ Posted December 15, 2023 Share #4 Posted December 15, 2023 Winter is the best time to do it! Put a small temporary lip at the lowest points, and have a temporary skating rink! Link to comment Share on other sites More sharing options...
Tizeye Posted December 15, 2023 Share #5 Posted December 15, 2023 You're lucky. You are not on a corner lot with sidewalks. Thanks to planning laying my sprinkler system, I know the two circuits along the sidewalk and purchasing the pipes, it is greater than the length of a football field. Assuming using a concrete attachment, do each section twice - across, then up and down. Two neighbors paid good money to have theirs done and was the trashiest job I have ever seen as they did the single sweep leaving streaks. Link to comment Share on other sites More sharing options...
Bikeguy Posted December 18, 2023 Share #6 Posted December 18, 2023 On 12/15/2023 at 11:44 AM, Tizeye said: Assuming using a concrete attachment, do each section twice - across, then up and down. This.. My driveway finished in front of the garage. Link to comment Share on other sites More sharing options...
Ralphie ★ Posted December 18, 2023 Share #7 Posted December 18, 2023 Definitely use the concrete attachment. The regular jet takes forever and removes too much of the concrete surface. Link to comment Share on other sites More sharing options...
Bikeguy Posted December 18, 2023 Share #8 Posted December 18, 2023 5 hours ago, Ralphie said: Definitely use the concrete attachment. The regular jet takes forever Yeah... I learned that the hard way. I used a surface cleaner th last 2 years. It is a LOT quicker. The 2nd year, the spinning nozzles didn't want to spin from time to time. I then blew compressed air backwards through the nozzles. That solved the problem. I still don't know how something under 3000 psi can get plugged up. 1 Link to comment Share on other sites More sharing options...
Ralphie ★ Posted December 18, 2023 Share #9 Posted December 18, 2023 8 minutes ago, Bikeguy said: Yeah... I learned that the hard way. I used a surface cleaner th last 2 years. It is a LOT quicker. The 2nd year, the spinning nozzles didn't want to spin from time to time. I then blew compressed air backwards through the nozzles. That solved the problem. I still don't know how something under 3000 psi can get plugged up. A surface cleaner like Olympic Deck stain remover applied with just a garden sprayer? I used that on my patio and it worked great but it gets expensive. Link to comment Share on other sites More sharing options...
BR46 Posted December 18, 2023 Share #10 Posted December 18, 2023 Got a old lawnmower? 1 Link to comment Share on other sites More sharing options...
Bikeguy Posted December 18, 2023 Share #11 Posted December 18, 2023 28 minutes ago, Ralphie said: A surface cleaner like Olympic Deck stain remover applied with just a garden sprayer? I used that on my patio and it worked great but it gets expensive Nope.. a concrete surface cleaner connects to my gas powered power washer. Link Link to comment Share on other sites More sharing options...
